It does not really matter what we think. Not really.
You have a budget of $300.00 and that is where all the thinking really comes to the front.
Your gaming and streaming songs and basketball is multi-tasking for sure.
1. I am not sure that you are slowed except in streaming Pandora or that is what you say.
2. In theory the 6300 will benefit you some. If the 4170 does not bottleneck your GPU then I doubt the 6300 would either.
3. Are you running the 2 bulldozer patches for Win 7. You should be.
4. A lot of games don't utilize 3, 4 or 5 cores anyway, so why not try a test?
5. Put the two bulldozer patches on in the correct order.
6. When you open the "application/s" you intend to run, then set the affinity of the game to the first two cores and the last two cores to say Pandora. See what happens. See if Pandora brings your 4170 to its' knees like that.
In the end your current board in theory limits you to the 6300, so much else about a cpu requires little thought when dealing with a $300.00 budget.
i am going to do my best to answer your bullet points. For someone who has limited knowledge aside from reading here and other places on the net, what people think who have forgotten more than ill ever know, does matter to me. But i get what you are saying
1: I know i play some cpu intensive games, and outside of some occasional lag and microstutter, its not that bad i guess. Most of my settings are on high and i get playable fps between 35 and 60. It does bog down in pretty intensive situations. I don't really notice to bad of a hit when watching a movie or the game.
2: ill be honest here, i am not 100% sure on the bottleneck. It is more of an assumption on my part. In guild wars 2 for example my cpu Will be pegged around 55 - 65 %, while the gpu is usually around 60-65%.
3 and 5: yes i have downloaded the fx patches for win 7, but i don't know if i installed them in the right order.
4. Very true
5: ill have to give that a whirl tonight, that would be going into task manager and changing the affinity there correct?
If it doesn't end up being a bog down or maybe its just some limitation somewhere else, i have no issues with scrapping the idea of the 6300. Im not opposed to just going with a cooler and other goodies.
I apologize for the long winded nonsense. But i really just want to make a good, smart and sensible choice.
