BenziT said:Hi,
I have just rebuilt my Compaq M2013 battery.
However, the charging lights stays on for about 5 mins. Thereafter, it starts to blink.
Any idea what is wrong ? There is no charge to the battery at all. Do i have to do anything eles? ie to reset the battery etc ?
I have left it to charge overnight. No charge to the battery at all.
Did you have to rest the PCB ?
If so , how to do it. < 3 volt per battery ?
Many thanks
Cyrix_2k said:Wait - each cell measures 3.9 volts!?!? Fully charged is 3.7 volts. If that's the case, then you should have enough working cells to get the battery pack to work. Since you said it is an 8 cell pack, I'm guessing it's wired as two parallel circuits each containing 4 cells in series. Either that or it's one series circuit with every cell in parallel with another. In both cases, final output should be ~14.8 volts charged.
Now, the blinking light on my armada indicates the battery pack is bad and won't charge so your pack probably has a bad cell. What you need to do is remove and test each cell individually until you find the one that doesn't measure the same as the others. In my case, the bad cells measured .4 volts instead of 3.x volts. There's probably no point in putting 7 cells into the pack, so revise it to be one series circuit of 4 good cells only. If you need help with what I'm talking about, I can try and post pics of what to do later.
haven't heard that before. Usually you reset the PCB through software, but I don't know exactly how that's done. Mine worked without being reset.BenziT said:OIC. Cause I was reading thru the forum. There was a comment to drain each cell to below 3 V as to reset the PCB .. Thus, I was wondering if this is true.
umm, I really hope you didn't... the negative side of the cell has metal to the plastic insulation, the positive side has an insulator between the metal center & plastic insulation.The battery packs from Compaq states 10.8V. Mine is a 6 cell. Thus, it should be in 3 x cell to form a series and each cell // to one..
I noticed that my laptop DISCHARGES the battery, instead of Charging it. Now, each cell is only 2.4V
Did I reverse the polarity ?????
