- Jul 5, 2003
- Frederick, MD
- Thread Starter
- #41
hmm, that's very odd then. Did you use new li-ion cells? If so, do you know their date of manufacture?
well, the old cells in the M300 battery were shot. The best one measured .42 volts, so even if it was just one bad cell causing the problems, all the cells would have permanent damage. My 8 cell's run time is still terrible - about an hour and ten minutes with the screen at full brightness - but you have to remember I used old cells. They actually came from a Micron Trek II that I bought for $25 over a year ago; I'm guessing the cells are probably a good 3 or 4 years old. Personally, I'd just buy one of these if you want an 8 cell battery. If you're wondering why I didn't, it's because I don't have enough money.MAReames82 said:I was wondering if you discharged all the cells in your M300 battery before hooking them back to the PCB? Also whats your run time on the 8 cell? I also have a M300 500Mhz model. I personaly brought my battery back to life by just replaceing one bad cell.
Cyrix_2k said:well, the old cells in the M300 battery were shot. The best one measured .42 volts, so even if it was just one bad cell causing the problems, all the cells would have permanent damage. My 8 cell's run time is still terrible - about an hour and ten minutes with the screen at full brightness - but you have to remember I used old cells. They actually came from a Micron Trek II that I bought for $25 over a year ago; I'm guessing the cells are probably a good 3 or 4 years old. Personally, I'd just buy one of these if you want an 8 cell battery. If you're wondering why I didn't, it's because I don't have enough money.
Cyrix_2k said:No, they were 50% charged according to the battery pack. I think the only reason some people suggest discharging the cells is so that if you were to short one by accident, nothing bad will happen. I was just careful to short anything while assembling the battery pack.
Let me know how that new battery works out. I'm thinking about buying one when I get the money. I did just buy a new battery for my Gateway Solo and it works great!
Cyrix_2k said:Only once. Right now, it's at my school running a hydroponics system until I get another machine up. I'll be sure to try calibrating it again once I get it back!
Bender said:I have a very old but nice Sony 505 333mhz celeron laptop I put new batteries in. It takes 18650 cells like most notebooks, although it only needs 3x of them. The stock 1550mah cells didnt hold a charge at all. I replaced the old cells with brand new 2600 mah LC 18650s from batteryspace.com I now get over 3 hours life from only 3 cells! The only downside of these cells is the price of $9.99 each. I googled batteryspace coupon code and got like 5% off though.
