- Nov 2, 2011
- Kansas City
Over the last 2 weeks I've read over 50 forum threads and researched as much as I could in preparation for my first WC build.
I have an i7 950 OC'd to 4.0GHz
2 GTX 570's
12 GB Ram
80 GB SSD
1 TB Raid 7200 rpm HDD
I bought a danger den cpx pro pump
got 2 danger den GTX 580/570 blocks for $140
danger den cpu block
swiftech 120.3 rad
1/2 inch ID tubing
6 120 fans on the rad
The system works really well and temps on GPU's have dropped 20C!!
CPU is running about 10 C cooler until I start up BF3, then the rad is overloaded. Going to install another swiftech 120.3 today.
idle temps:
-GPU'S 35 C
-CPU 40 C
load temps:
-GPU's 55-57 C
-CPU 70 C
rad is definitely overloading.
What I learned:
-graphics cards are really really thin, just a PCB with a giant heatsink
-T line or Res should be right before pump intake the rest of the order doesn't matter for the most part. My T line is before the rad which is before the intake. will move it when I install my second rad.
-WC'ing isn't as hard as I expected
-Pressing the power button for the first time with water inside my comp is ****ing scary!
-you never have enough rad!
2 GTX 570's
12 GB Ram
80 GB SSD
swiftech 120.3 rad
1/2 inch ID tubing
idle temps:
-GPU'S 35 C
-CPU 40 C
load temps:
-GPU's 55-57 C
-CPU 70 C
What I learned:
