- Jun 10, 2003
- Plymouth, UK
And DAMN, I Love having my new RAM - just bought 16GB Kingston HyperX LoVo 1600MHz 1.35v in two sets of 2x 4GB
(KHX1600C9D3LK2/8GX)
I was running on only 3x 1GB Corsair Dominator 8-8-8-24
and Really struggling with Page File thrashing on the 2nd HDD
I came across Dataram's RAMDisk personal versin is free as long as you do not need to make a RAMDisk of over 4GB and seems very reliable & fast so far.
I set up a 4GB RAMDisk for the pagefile & now all my HDD's are barely ever running - a real life saver
Being on a tight budget can waste a lot of time picking the Right hardware for the money lol
and the good gear is So Overpriced in the UK -.-
INTRO to this Experience:
Ended up looking at the low voltage stuff hoping it would OC well from having used better chips than normal + seeing the odd good review by chance
So, cutting the story short:
Saw the G.Skill Sniper 1600MHz 1.25v set do well in a review or two - but Most reviews (site and user) came up pretty mixed leaning on the negative side of things
Saw the Samsung Green MV-3V4G3D/US - is a super low profile 1.25v 1600MHz 2x 4GB using the latest Samsung 30nm chips. I hear nothing but Good stuff about this set
But... only Very few UK suppliers and they are price hicking like Crazy ($46.99 in US and has worked its way up in price to the "Sale Special Offer" of $75.98 now lol
About now I was starting to get Really bored of searching through reviews and struggling (PageFile thrashing all the time on my 2nd HDD) on with my poor 3x 1GB Corsair Dominator 8-8-8-24 set (I mean, look how long this post is getting and I'm trying to keep it short)
Then saw some Good things on many sites about the great looking Kingston HyperX LoVo 1.35v 1600MHz 2x 4GB kits
They seemed capable of miracles, Super Tight timings and or High speeds!!!
One guy managed 1908MHz @ 7-7-7-20timings with 1.65v
Sadly this was on the now discontinued 1866MHz LoVo model using the excellent "Elpida Hyper" chips
The Right RAM & Some Testing
The current 1600MHz Green sets are still shipping in the old (clasps at top) as well as the new style (holes along top) :
(you get the idea)
I have to say this is some nice looking memory + Easily fits under my Noctua NH-D14's heatsink which was partly a factor in my choice of this RAM
After much digging I found the newer Genesis model of the 1600MHz LoVo RAM uses the 30nm Micron D9PFJ (DA-125) chips. Sadly these do not hold quite such tight timings as the older Elpida Hyper ones, but they are Quite happy to go for high speeds on slightly relaxed timings and run cooler.
One thing I Must say surprised me when testing was How variable each stick was in its capabilities!!! For example out of the 4 sticks I bought, testing at 2,000MHz 9-9-9-27 one stick at a time (all testing was done @ 1T of course):
1 = Passed All tests @ 1.6v - (did not like tighter timings or 1.5v)
2 = Could benchmark, but failed Prime95
3 = Sometimes could load Windows @ 1.64v
4 = Lucky to see Login Screen@ 1.64v
After too Many hours of testing (Damn but I need an SSD for this **** lol) late last night I had the Best 3 sticks all running Almost prime95 stable @ 2,000MHz 9-10-9-27 with 1.60v before I backed down to my tested and stable 1,600MHz 8-9-8-24 with 1.5v for the night and some folding. Not all the sticks were happy with 8-8-8-24 but that 9 seemed to make things sweet
And Some Interesting Benchmarks
Initially as you can imagine I did not want to side grade to more RAM but with lower timings at same speed and was feeling a little sad I could not get the 8-8-8-24 timings I had run on my old RAM...
But having done a little benchmarking, to which I might add some more later, showed up some surprising results.
In most reviews I have read on this stuff people running same speed+timings tests have shown this RAM to have a slight advantage over others tested.
Below are a few SiSoftware Sandra Benchmarks with the old and new RAM:
Corsair Dominator 1,600MHz 8-8-8-24 1.64v
Aggregate Memory Performance : 21.485GB/s (Ranked 18,303 - Higher than 90.44% results)
Memory Latency : 21.7ns (Ranked 2,154 - Higher than 82.75% results)
Kingston HyperX LoVo 3x 4GB 1,600MHz 9-9-9-27 1.4v
Aggregate Memory Performance : 24.622GB/s (Ranked 11,921 - Higher than 93.78% results)
Memory Latency : 22.5ns (Ranked 2,747 - Higher than 78.09% results)
Kingston HyperX LoVo 3x 4GB 1,600MHz 8-9-8-21 1.5v
Aggregate Memory Performance : 25.087GB/s (Ranked 10,968 - Higher than 94.28% results)
Memory Latency : 22.0ns (Ranked 2,390 - Higher than 80.94% results)
Kingston HyperX LoVo 3x 4GB 2,000MHz 9-10-9-27 1.60v
(not Prime95 Stable – need to tweak some more…)
Aggregate Memory Performance : 27.618GB/s (Ranked 6,497 - Higher than 96.61% results)
Memory Latency : 20.2ns (Ranked 1,122 - Higher than 91.03% results)
The increase in bandwidth by 3.137GB/s at only 9-9-9-27 compared to the Corairs 8-8-8-24 both running 1,600MHz was a nice find
FarCry 2 is a game I have seen responds quite well to increases like this in reviews I read. Going from Corsair Dominator 8-8-8-24 1,600MHz to Patriot Viper II it gained 3 - 5 fps. This Kingston I know beats out the Patriot memory, so all in all this leaves me Pretty Happy with this new RAM running with 1,600MHz 8-9-8-21. Running only 1.5v and saving a little power over a year cannot hurt either, something I would loose out on running the higher speeds which seem to want volts
Later when my patience returns I will play more with some 2,000MHz speeds and getting them rock solid.
Is good to know that having some Good RAM working with nice settings can make a noticeable real world difference beyond that of just benchmarks.
I know I would feel the extra smoothness an extra 5fps could bring me in games on my system. Until I upgrade the GFz card to the latest monster I need all the extra I can get ^^
My motherboard lets me run 4 sticks in Tri channel mode with 2 sticks occupying the 1st bank, but I was having trouble getting them to run 1T like this, but have done limited testing so far. Something else I will explore the possibilities of later - though will mean adding the weakest stick out of my set of 4...
Well thanks for reading and hope it was a help to some of you
Main Parts System when I wrote this up:
Gigabyte X58A-OC
Xeon X5650 @ 3.6GHz 1.15v(idle28c folding58c)
Noctua NH-D14 (140mm fan only @ 1.1k rpm)
3x 4GB Kingston HyperX LoVo 1,600MHz 8-9-8-21 1T @ 1.5v
Asus 5850
Seasonic S12 500W (SS-500HT Active PFC F3)
Linky to a Google translated version of a nice to the point review I found on the same stuff!
(you get the idea)
Gigabyte X58A-OC
Asus 5850
