- Jul 15, 2008
- Suffield, Connecticut
Here's what I've been working on this spring. I don't have a name for it yet xD
Specs on the rig are:
Zotac H55 ITX (Shipped)
Intel i5 750 (Have)
4GB G. Skill DDR3 (Have)
Gigabyte 5770 (Shipped)
OCZ Vertex 30gb (Win 7) (Have)
WD 320gb 2.5" (Files) (Have)
Corsair H50 push/pull (Have)
Ultra X4 400w modular (Have)
Silverstone SG05b (Have)
These first pics are just with the PSU and H50
Here you can see the sponge painting I did. Black case with white paint, applied with a household sponge
I mounted the front fan outside the case, to allow for the H50 and another fan inside. The fan fit right into the place where the mesh used to be on the stock front panel. I used some caulk to hold the fan on (prevents vibration) and used some spackle to fill in the gaps between the fan and the panel.
Cut a hole in the top mesh for the PSU's fan using some tin snips
Hope you guys like it so far, more to come when the rest of the hardware arrives!
Also, for those not familiar with the case....this is what it originally looked like
Intel i5 750 (Have)
