XP-120 + $630 un-IHSed cpu = $630 paperweight.
It's hard to seat an XP-120 on an open-die CPU, because it doesn't go straight down, it puts down uneven pressure when you mount it. You do know how fragile the core of a CPU is, correct? Putting on an XP-120 unevenly will definately crush the poor little core. And it is VERY hard to place an XP-120 on an open die, as you have to loosen the screws holding the clips, put the clips in while holding the heatsink steady, and then tighten them in. Now, i'm not positive if this is possible (i don't have an XP120/90), but I ahve seen this method before.
Now, if it was a Zalman, maybe
