- Feb 17, 2010
- Manassas, VA
I mean sure, some might be more likely to be bad than others, but in the end you RMA the bad kits and keep the good ones and that's the end of it, irrespective of the brand.
Good FOR YOU... but your experiences do not define a products failure rate nor give a remotely accurate representation of their it. You are but a drop of water in a large large lake.
@ Crucial memory.. no clue... do you have any facts outside of your experience with them?
The bottom line is that what they are rated for is on the package. If they dont work, they dont work. Anything outside of that fact for 99.9% of users are simply just DOA sticks to RMA. Knowing what you say you know and helps will help almost nobody IMO.
Dog I have some sport versions that run 1866 @ 1.35v and the only 1.65v listed for Crucial on new egg is: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148625
One set! The rest is 1.5 and 1.35.
Nope, price doesn't matter in the slightest. Only accuracy matters. Why would price matter? We only care about accuracy. Guess what? That's all they care about too.Those > $1M testing machines come in both the wafer-probing versions and versions that test whole packaged chips or even finished memory modules.
But according to you or someone else who's agreed with you, it doesn't matter whether the modules are screened with expensive machines or with machines costing 99.95% less.
Do they? Have you ever personally binned a stack of RAM? Do you actually know how the process works? Have you binned anything?Actually they do test for max clocks and tightest timings because the only way to bin the chips is by is by running them at the fastest specs and seeing which fail, then take the failures and test them at slower speeds, etc. I suspect module makers do the same, especialy because they use so many chips that are rejects or overclocked and don't know how well those chips can do. It's probably only the final testing of the labelled modules that's done at fixed, preset timings.
You make no sense, at all. Binning a stick with 16 chips on it for 1h takes a 16th the time binning each chip individually for 1h takes.For the opposite to be true, wouldn't each module have to average fewer than 1 RAM chip?
Who said anything about machine speed? Did I? (cliffnote: Nope)How much of that is because they test more thoroughly than the chip makers do, and how much is due to them using slower testing machines?
Because they can bin them off the production line. If 75% of their samples pass they can breath on things and raise that a bit, then the modules that don't make it to those peak speeds can be sold at lower speeds.Why would they use the highest rating that only most of the test sticks pass, as oppose to 100% of the test sticks? If you're saying different module companies have different standards, which companies have the lowest standards?
Nope. Not worse, either. The end result is identical.Is that better than using chips guaranteed to meet those timings?
What about those? They happen with everything. I've had genuine straight from intel CPUs die that way (actually only made it 5m at 100% stock, wasn't even out of the BIOS).What about modules that consistently test fine during the first 15 minutes of computer operation but fail later? Some people will replace them, others will just raise the voltage or slow the timings and continue to use that "dead" memory.
That's across every batch ever produced. If you're following that logic, it's illogical to believe that every RAM chip off a production line geared towards "1600MHz" chips will be correct.Is that for 680K and 655K chips from the same production run? Batches vary in quality, even when clean room temperature is regulated to within 0.5 Celcius. It's illogical to compare speed bins from different batches, unless it's known that the batches are consistent enough with each other.
I ask again, where is your proof? Where is even a hint of proof? So far I've seen none, at all.How can a brand's quality be good if its manufacturer's standards have allowed up to 2 faulty bits per module?
Any backup for those numbers that are spit out as factual?Then roughly 10% of the sticks are bad, and almost always those sticks made from no-name or overclocked chips. Probably a lot more than 0.1% of the buyers have to spend extra time or money getting them replaced.
How many modules from how many kits have you personally tested? How many high speed modules have you personally tested? Do you even have a system capable of testing high speed RAM?That's all I'd care about, too, provided all modules were the same quality, but those made with branded, nonoverclocked chips have been a lot, lot more reliable for me.
Look at Crucial alone: how much of their memory has been bad, outside their Ballistix lines?
Some people are making ridiculous comparisons between batches of chips, and it's not unexpected for one batch's slower rated chips to perform better when overclocked than another batch's fastest rated chips. Nobody has answered whether such bins were from the same batch or not; it's as if they don't have any proof.wow... this is a thread of sillyness.
What does it matter if ram which is timed for both 1600 and 1866, comes off the same chip? Who cares? What does it matter? As long as it functions as advertized at the speed advertized, error free, then it shouldn't matter one bit.
I don't want to pay to ship RMAs, especially multiple RMAs, and it's easy to avoid defects in the first place.I mean sure, some might be more likely to be bad than others, but in the end you RMA the bad kits and keep the good ones and that's the end of it, irrespective of the brand.
IOW memory modules are just like power supplies -- the advertised claims are always true, and all the products are good.
what are the actual differences in doa and return rates between Sammy and the rest? You have those numbers or are will still using your microscopic sample size to make a broad blanket statement?I don't want to pay to ship RMAs, especially multiple RMAs, and it's easy to avoid defects in the first place.
What you quoted wingman is downright hilarious to me. He acts as if Sammy return rates are exponentially better than other vendors. Truth is nobody knows. I GUESS however that they are all within a couple % of each other and all well under 10%.
