Finally got the compressor going. It had a bad controller. Now the system won't boot with an error 34. That means the CPU isn't making good contact with the pins or I bent some. Now I have to rip it all apart to check.
What stinks about Lil Devils' systems is the computer starts at -25c. Then he has some routine in the controller to check the 12v line, but there is only a two connector cable to check and he says to plug it into a fan connector or motherboard fan connector. That's kind of hard when fan connectors are 12v, 5v, ground and the cable is 12v and ground. If the connector doesn't sense the 12v line after 8 seconds, it turns the system off.
