Hey everyone, first time poster here. Just thought I'd share my experience with this AIO cooler upgraded to full quad rad and 250 res.
System Specs:
Rampage IV Black Edition
i7-3930k
32gb 1866 HyperX Beast Ram
Zotac 980ti Amp! Edition
Seasonic 1250 PSU
Thermaltake Core P5 (green)
LED strip kit
LEPA EXllusion 240 AIO Cooler
So I wanted to get some better performance out of my aging system so upgraded my cooling to get some overclocking on. Granted I used to run this system at 4.5ghz but nothing really pushes my system so much to warrant the extra heat and wear/tear so just kept it around it's boosted 3.8ghz. Running a aida64extreme stability test I would see upwards of 70-80C package temps, my radiator would get hot and just wasnt cutting it in the long run. This is what got me to look into expanding this AIO to suck out more heat.
Now I can run a stable 4.7 and keep it around mid/high 60's. However to me and just gaming I don't need it quite so high especially since the pump is going to be the limiting factor in performance at this point. I let my board just auto to 4.25ghz and never hit 60C on stress tests. Basically if anyone is looking to get a custom loop build but not quite comfortable enough then this AIO is perfect besides being really hard to get a small bubble bled out of the cpu block but I use it as a flow indicator as it still pushed quite a bit of water surprisingly. This was a budget build since I had the AIO and if I ever want to upgrade to GPU cooling etc all I need is a pump and cpu block.
System Specs:
i7-3930k
Seasonic 1250 PSU
LED strip kit
