- Mar 28, 2004
This is the silent case with the door in the front. I know that these cases are not great for OCing, but I dont plan on doing much of that so I dont think it will be a big problem. But still, is the air flow at least decent in these cases? I plan on adding a side intake and top blow hole. Also, they get their intake from slits in the bottom front correct? Are these slits filtered, if so, are they removable to be cleaned or could I mod a filter on there?
Does anyone have a reason why I definitely should NOT get this case?! Thanks
HERE IS THE CASE
EDIT: sorry, the reason this thread is in here and not "cases" is because I want input from you guys mostly concerning the air flow and cooling possibilities of this case.
HERE IS THE CASE
