Yes, I know bad me for buying a cheap board(ASUS M5A97). Now on to the topic.
My cheap Phenom II 1045T build has hit a little OC issue. I'm getting about .06v vdroop which is turning into the difference between 3.8Ghz fully stable and 3.8Ghz mostly stable. This ASUS M5A97 has an LLC option but it ramps up voltage far too much to be practical. Though as a member of these forums when I saw my voltage way up over 1.6V I totally restarted and found at least a temporarily workable OC at that voltage.
If I'm not to exceed 1.55v with LLC on I need to go with a base Vcore under 1.49v and cannot POST. If I up Vcore to 1.5v I can post but LLC will push load voltage too high. But if I don't use LLC I'll need to use 1.57-1.58v for full stability and would rather not hang around over 1.55v all day.
Any suggestions on how I may get it to POST with LLC and still run a completely stable voltage? Currently thinking of using LLC and low clocks to POST then using software to overclock but I've never gone that route before so am I ?
