- Aug 17, 2006
- Costa Rica
Ok so I am really just unsure which to purchase.
Both the Logitech and Razer have 2000 dpi and Laser guided.
The G5/G7 is:
Tracking Resolution: 2000/800/400 dpi (user selectable)
Image Processing: 6.4 megapixels/second
Max. Acceleration: 20g
Max. Speed: 45—65 inches/second (depending on surface
USB Data Format: 16 bits/axis
USB Report Rate: 500 reports/second
Sleep Mode: Disabled
On-the-fly Sensitivity Switching: Provides instant access to 3 sensitivity levels — 400 dpi, 1200 dpi, and 2000 dpi — before driver installation
An ultra-high resolution engine churns images at an astounding 6.4 megapixels per second
A massive (30-pixel by 30-pixel) sensor array and precision laser technology provides best-in-class performance and tracking
8x faster than conventional mice
Adjustable Weight Cartridge: Use 38 grams of adjustable weights to tune the balance and heft of the G5 for the control you need to dominate the competition
Polytetrafluoroethylene gaming feet
The Razer is:
2000 DPI Laser Engine Powered by Razer Precision
1000 Hz Ultrapolling with 1 ms response time as compared with 125Hz/8 ms response time used by other conventional gaming mice
32KB Onboard Memory Powered by Razer Synapse
Up to 3 customizable weight standards and optional dummy buttons
Zero-Acoustic Ultraslick Teflon feet
16 bit data path, as compared to 8 bit and 12 bit data paths used by other conventional mice
High speed motion detection, up to 45ips and 20g / Over 7080 frames per second
Always-On mode pioneered by Razer - the laser engine sensor never powers down to provide instantaneous response at all times during gameplay
Award winning Razer drivers featuring On-the-Fly Sensitivity DPI adjustment pioneered by Razer
GlowPipe non-slip side rails
Ergonomic ambidextrous design
Ultra large non-slip rubber coated mouse buttons
Now im looking for the best response, accuracy, and quality.
And if the Logitech seems better than the razer....would wireless (G7) drop in response time?
Thanks,
Brandon F.
Sry for so much info^^
The G5/G7 is:
The Razer is:
Thanks,
Brandon F.
