- Aug 1, 2002
- Michigan
My case is a mid tower but it seems a bit small and is restricting the air flow a bit, which is probably why I can't go past 2.9GHz stable. So I've been looking into larger cases and these sticks out as being much bigger with big fans:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811215006 has 250mm on front and monster 360 (over 14 inches) on the side.
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144205 has only 120mm fans but there are 2 rear 120mm that I can probably replace with a pair of Delta 220CFM fans if the space permits. (or mount them on outside!)
Fan noise will not be an issue with me being deaf. If I could I would hook up a shop vac with the vac hooked into the back and just suck in the 1000 cfm range but it's also expensive to run 24/7 with all those current it needs.
Any other suggestion? I'm still waiting on the free money Gov't issued
or
