It is every bit as good as a D15, if not better. It can handle my 5900X @ 240w. That is the absolute most power the socket will give me while using PBO. But I have seen 260w+ manually.Would that be enough to cool an overclocked 12700k? Because I was kind of thinking of going back to air cooling.
What's every bit as good as a D15? You lost me.
Torrent Compact and a big Thermalright cooler, problem solved
It means it is as good, or better than a D15. I am leaning towards slightly better. But to be fair D15 has been around forever, and the only thing updated was its looks, they have not retuned for the new generations of CPUs that are much different than what we had when the cooler originally came out.What's every bit as good as a D15? You lost me.
Something from less standard cases - https://www.jonsplus.com/products/i400-sg.html
But as I remember it was hard to get in the US.
You will be surprised how well are these cases made. They have also great airflow bottom to top. Noctua recommends some of their cases for their passive CPU cooler. The only problem is that most their cases are designed for air cooling or a single AIO, and it's hard to install any larger custom water loop. Most have also covered internals or have dark glass panels, so they're not the best if you want to see components inside.
I like their high quality and clean exterior design. I guess that i400 has actually complicated internal design, the same as i100. I mean, there are multiple parts, brackets and other things that fit perfectly. The price is very reasonable for what we get, at least compared to all other brands.
Ah, one more thing. I guess they still don't have PCIe 4.0 risers in retail cases. It supposed to be added, but it takes time from production to store availability.
You don't need to put anything on the side panels. It won't help for this case, but if the side panels are installed the same way as in smaller models, then there won't be any vibrations. At least I had no problems with the i100 Pro.Does anyone know whether video card orientation actually affects cooling in any way or is it just for appearance? Seeing as I’m getting the version with metal sides cooling efficiency is the only consideration.
I’ll likely slap some Dynamat Extreme on the side panels to kill any unwanted resonance. I’m rather hoping this case is quiet also. I suspect the wind tunnel design should lead to good cooling efficiency so hopefully lower fan noise, otherwise I guess I’ll order 6x Noctua fans to drop the noise unless there are better quiet fans have come about in recent years?
