- Aug 23, 2007
Currently my PC is so quiet on idle you can't hear it on at all. On full load (gamin or rendering) it could be used in a library. I'm looking for a pump/rez combo (ideally) that is quiet, exceptional quality, and will only be used to at most down the line cool my 8700k, Vega 64, and push flow through a, EKWB EK-CoolStream SE 240 slim dual radiator and a 360 slim triple radiator. I am leaning towards the EK-XRES 140 Revo D5 RGB PWM for $164.74 + Shipping on Amazon.
All advice welcome. The EK-FC Strix RGB VEGA 64 water block & back plate come in next week so I'll have slightly more height clearance than shown.
I'll be most likely drilling holes in the floor of my case to mount it. I have about 3.5 inches between the end of the VEGA 64 and the 140mm fans on the 280mm Rad in the front and over there my height clearance goes up to about 10inches comfortably but w/ only 3.5 inches of width...
As a side note I'll also be drilling a larger hole for cables closer to the power supply for better cable management.
Thanks team!
Thanks team!
