care to explain this info
Add Item With Selected
Manufacturer Warranty
Beyond any applicable Newegg return policy, this item is warranted independently by the product's Manufacturer. Below is a summary provided for convenience only and may not be accurate or current. Use this link for full details.
* Manufacturer Limited Warranty period (parts): 3 years
* Manufacturer Limited Warranty period (labor): 1 year
Manufacturer Contact Info
* Manufacturer Product Page|
* Website:
http://www.dfi.com/portal/CM|
* Support Phone Number: 1-510-226-7500
* Support Website|
* View other products from DFI
Return Policies
This item is covered by Newegg.ca's Standard Return Policy.
* Return for refund within: 30 days
* Return for replacement within: 30 days
* Restocking Fee: Yes
Customer ReviewSpecifications
Review Summary (read all 17 Reviews, write a review)
5
newegg
58%
4
newegg
12%
3
newegg
24%
2
0%
1
newegg
6%
Product Rating:
Total Reviews: 17
Pretty good
white Reviewed By: james on 3/26/2010
Rating + 4
Tech Level Tech Level: high - Ownership: 1 day to 1 week
This user purchased this item from Newegg
Pros: It lets me put a core i7 into a mini-itx case.
Cons: The manual doesn't explain the bios settings.
It won't let my USB keyboard get into the bios. I have to plug in a PS2 keyboard to do that.
The tweaking software requires .net 2.0, and I can't find a way to get it on Windows 7 64-bit.
I wish it had a firewire port in the back.
It only has 3 SATA ports.
Other Thoughts: Intel Core i7-860
Mushkin Enhanced Blackline 8GB (2 x 4GB)
SAPPHIRE 100293L Radeon HD 5570
OCZ Vertex LE (Limited Edition) 100GB, Western Digital Caviar Green WD15EARS 1.5TB
Microsoft Windows 7 Home Premium 64-bit
1 out of 3 people found this review helpful. Did you? Yes No
Thanks for the valuable feedback you provided!
Works OK
white Reviewed By: leemik on 3/9/2010
Rating + 3
Tech Level Tech Level: somewhat high - Ownership: 1 day to 1 week
Pros: can't think of any other LGA1156 Mini ITX board
seems to work great once you get around bios issues.
Cons: not your typical bios ui
having bios settings save issue as others noted
Other Thoughts: Specs: Core i5 650, 300W shuttle power supply, Shuttle KPC case, 4GB GSkill Ripjaw PC3 10666, WD "Green" 1TB drive, HIS Radeon 5770. Dynatran cooler
mild overclock to 3.5GHz
I built this system to be a HTPC with capable gaming at 1920x1080. Also needed it to have as low as possible current draw.. Everything seems to work fine once I got around the bios issues.. I found that my settings wouldn't save if I hit escape and save "OK".. but it seems to save when i hit F10 before exiting..The bios seemed to want to choose some random settings for me as well at times so make sure you set everything and hit F10... I eventially managed to get the settings i wanted in there.. the system is stable and I'm happy I don't have to mess with the worst bios known to man!
4 out of 5 people found this review helpful. Did you? Yes No
white Reviewed By: blaster5k on 3/4/2010
Rating + 3
Tech Level Tech Level: high - Ownership: 1 week to 1 month
Pros: - P55 in an ITX form factor
- Good board layout
- Power consumption is as low any mATX board out there
Cons: - The English is poor in the BIOS and manual
- The manual doesn't do a good job of explaining the BIOS functionality
- The BIOS is very buggy
Other Thoughts: I'm running this board with a Core i5 750. My main complaint is the BIOS. The first time I change from IDE to AHCI, I get gibberish on the top of my screen when it POSTs, it reboots, and all settings are lost. It usually sticks the second or third time.
Also, if I change settings in some combinations (ie. Enable SpeedStep, Enable Turbo Boost, Enable C-State), when it POSTs again, it just decides to overclock my processor! It set the base voltage to 1.25V and BCLK to 166, putting the processor at 3.33GHz. I had some major heat/power issues as a result. It also messed up my DRAM settings. It wouldn't let me change the BCLK and I couldn't fix some of the DRAM settings, so I had to reset the CMOS every time this happened. Not cool.
Since this board is more or less one-of-a-kind, I can't knock it too much. When the BIOS settings are right, it runs okay. I've got a powerhouse of a machine inside a tiny case. I don't know if I'll buy from DFI again though.
3 out of 3 people found this review helpful. Did you? Yes No
Model
Brand DFI
Model LANParty MI P55-T36
Supported CPU
CPU Socket Type LGA 1156
CPU Type Core i7 (LGA1156)/i5 (LGA1156)
Supported CPU Technologies Supports Intel Turbo Boost Technology
Chipsets
North Bridge Intel P55
Memory
Number of Memory Slots 2×240pin
Memory Standard DDR3 1600(O.C.)/1333/1066
Maximum Memory Supported 8GB
Channel Supported Dual Channel
Expansion Slots
PCI Express 2.0 x16 1
Storage Devices
SATA 3Gb/s 3
SATA RAID 0/1/0+1/5
Onboard Video
Onboard Video Chipset None
Onboard Audio
Audio Chipset Realtek ALC885
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Intel 82578DC
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 2
USB 1.1/2.0 5 x USB 2.0
eSATA 1 x eSATA/USB combo port
S/PDIF Out 1 x Optical, 1 x Coaxial
Audio Ports 6 Ports
Onboard USB
Onboard USB 2 connectors for 4 additional external USB2.0 ports
Physical Spec
Form Factor Mini ITX
Dimensions 6.7" x 6.7"
Power Pin 24 Pin
Packaging
Package Contents LANParty MI P55-T36
1 x User’s Manual
1 x SATA + power cable
1 x I/O shield
1 x DVD Driver
1 x Creative X-Fi tool CD
4 x Mini Jumpers
1 x Smart connector (Front panel+USB)
Home
Home. >
Computer Hardware0_. >
Motherboards1_. >
Intel Motherboards2_. >
DFI3_. >
Item#:N82E16813136073
