Hello all!
I'm looking for a Northbridge X58 Chipset heatsink that's compatible with my Intel DX58SO motherboard. I will be overclocking so something with stock or better heat dissipation is desired. I no longer have the stock heatsink for the northbridge (don't ask how I lost it).
I've found a couple different heatsinks but I don't know if they're compatible with the DX58SO. The mounting holes on this board seem farther apart than what I see on other boards. I tried taking some measurements of the four mounting holes and this is what I got:
Horizontal Holes: 66.675mm apart
Vertical Holes: 47.625mm apart
Diagonal Holes: 80.9625mm apart
Here are two of the heatsinks I was considering:
-Enzotech Cnb-r1 and 40mmx40mm fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835708002&Tpk=cnb-r1&IsVirtualParent=1 and http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=20870
-SilenX IXN-40C Copper Chipset Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226019
I'm struggling to find a new chipset heatsink for this motherboard. Can anyone help me figure out if the above heatsinks will be compatible with the Intel DX58SO Northbridge? And if none of the above are compatible, do you know of any that are?
