PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($329.99 @ B&H)
Motherboard: Asus MAXIMUS VIII IMPACT Mini ITX LGA1151 Motherboard ($234.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($75.99 @ Amazon)
Case: Fractal Design Define Nano S Mini ITX Desktop Case ($64.99 @ NCIX US)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Other: Sandisk SD8SN8U-1T00-1122 X400 1TB M.2 2280 Solid State Drive ($254.79)
Other: MSI GeForce GTX 1080 DirectX 12 GTX 1080 SEA HAWK EK X 8GB 256-Bit GDDR5X PCI Express 3.0 x16 HDCP Ready SLI Support ATX Video Card ($809.99)
Other: ekwb parts ($650.00)
Total: $2594.62
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-06-22 15:16 EDT-0400
Watercooling parts:
EK-FB ASUS M8I Monoblock - Nickel
-Not sure if i am going to get the mono block or just a CPU block yet. Has anyone used the mono block? I know it will help cool the MOSFETs but not sure how much that will help with overclocking the board.
EK-RES X3 110
EK-XTOP Revo D5 PWM - Plexi (incl. pump)
EK-CoolStream SE 240 (Slim Dual)
-I would like to try to fit two in the case if the top mounted rad does not hit the power board
EK-HD PETG Tube 10/12mm 500mm
EK-HDC Fitting 12mm G1/4 - Black
EK-AF Angled 90° G1/4 Black
Case fan:
Thermaltake Riing 12 LED RGB
-Has anyone used these fans or is using them right now? how well do they look in the case? How well do they work? I cant really find any good reviews on them youtube/ google.
I might add some other RGB LED in the cases if the ones on the Thermaltake do not look how i want them to. I am also thinking of making a it a either having baby blue pastel or yellow pastel color in the tubes. Anything that is not black on the motherboard/psu/memory will get removed or covered up. I would really like to in the future change the tubes to glass but I am not sure on the right now since i have not ever worked with the glass tubes.
If you have any suggestions on the build please let me know. I am hoping to start to buy parts and build it as soon a the 1080 comes into stock (so sometime late next month if not august).
Total: $2594.62
Watercooling parts:
EK-RES X3 110
Case fan:
