- Jan 12, 2015
Dear Members,
I have a leak in my SS that was built by Mythicaltech at Xtremesysytems. This is a upgrade over the one I got from bmwbaxter (-35c) as it has a 1hp compressor and a BartX (-52.3c) evap.
I have a local HVAC tech working on fixing and repairing the SS.
The HVAC tech says that the Compressor states r-22 to be used BUT wants to know what would you guys recommend to be used for best performance.
- I found this info in an old email from Mythicaltech on what oil was used - At around 2 tomorrow I will be testing it with r290 to make sure it is running smoothly and then Monday it will get its final charge of r507.
Thanks
Thanks
