Alright, so after putting this build together I've just been running into loads of problems.
Not regular stock problems, I can still play games and everything with no issues,
but I really just want to nip these OCing problems in the butt.
First issue is with the GPU. When it was in the 6700k build it would run 3dmark and vrmark all the way through, no issues.
But it wouldn't even open pcmark.
Now it's the opposite, I can open and run PC mark all the way through, but I can't get more than 5 seconds into either of the
others without the test crashing.
Another odd thing is in cpuZ, It shows the GPU has only 4gb of ram. Is that normal? Or could that be related to this issue?
Upon googling some of the symptoms, most people, from what I see, RMAd their cards. But lately it's difficult due to the fact
that it's an O8G, which I guess is more rare than the A8G. But it worked fine in the 6700k build, so why not this one??
Second; The RAM, I have 2 32gb sets in now, both Trident.Z 3200, one RGB one Not. The non RGB worked fine in XMP on the 6700k build
but XMP won't work on this one. I tried it with just each set, individually, and it still won't boot in XMP mode.
The light research I did on this suggested to turn off the cpu turbo boost, which I did and it yielded the same results.
It also won't boot in anything higher than 2133 for some reason, which is very frustrating. I even tried jsut setting it to 3200 without XMP
Still, the same issue. VERY frustrating.
Any thoughts or suggestions would be much appreciated!
