- Feb 15, 2006
I found a thread for the m2n-sli deluxe where you can read the vcore and vdimm using a volt meter. http://www.xtremesystems.org/forums/showpost.php?p=1545990&postcount=15
Just ground the negative and put the positive on the respective points shown. I searched and didnt find any thread on OCForums showing this.
I have a 5200+ with f3 stepping its only 2.6 stock with vcore 1.2~1.25 and some ballistix ddr800 2.2 vdimm memory. I have the cpu running at 12x250 for 3ghz @ 1.2875 in bios and the memory set to 2.2 volts in bios and they are running at HT1000 & DDR1000 5-5-5-15. This setup is stable and my memory passed memtest just fine. cpuz gives me vcore reading of 1.200 idle and 1.168 load for a vdroop of 0.032 Direct readings using voltmeter is 1.290 idle and 1.170 idle for a vdroop of .120
The memory only gives me a reading of 2.03 idle and 2.06 load.
My question is should I use the direct readings? I dont really plan on pushing my ram but to maybe 1066 and it has booted just fine at ddr1000 4-4-4-12 but fails memtest and prime95 quikly. I have only set it to 2.25 inbios so far but never voltmeter tested it then and it still failed. should I up voltage untill my direct readings are 2.2? I have crazy cooling on them I laser cut dual 120mm fans in my window see here: http://www.ocforums.com/showthread.php?t=591271 It would be nice to get 4-4-4-12 at ddr1000 out of these babies I just dont want to fry them. Should I trust the direct readings anyone else done this?
Also what do you think about the vcore readings it seems close to the set bios value when reading with a voltmeter but my vdroop is really big. Using 4 different software readings it is always reported .032 so my direct reading is 4 times larger than software says. what shoudl I trust?
