- Jun 15, 2009
- Italy
I own an ASUS M3A78-PRO (780G/SB700) Mobo which is great to play with for OCing but it has many limitations on voltage regulations. I'm currently running on the latest BIOS (v1404) and I have two catastrophic limitations:
(1) CPU volts [up to 1.3V]
(2) RAM volts [from 1.9 to 2.3V]
About point (1):
My CPU (AMD 940BE is rated for 1.35V for normal operation, so from BIOS if I choose manual setting I can only underclock and not even get to par!! Measuring with CPU-Z and AMD Overdrive I actually always read 0.025V less than what is set in the BIOS but that is a fixed offset so I just take it into consideration and always add 0.025V to what I want to set. If I use AMD OD to push the volts up then it raises at will.
Is there a way I can "unlock" the BIOS to go higher than 1.3V? Have I got something wrong here? What's up with my BIOS/Mobo? Any ideas?
About point (2):
If on BIOS I set my RAM to manual 1.9V, or any other value for that matter, I get an AMD OD reading of 1.8V. Another strange thing is if I set the lowest value on AMD OD (0.8V) my system is still happy and stable; which probably mean that I have no control over RAM voltage. This is hindering my overclocks badly! If I set the RAM to 1066MHz I can't even boot probably because of the low voltage (1.8V standard).
Any ideas?
[CPU] Phenom II 940BE 3GHz
[RAM] Corsair 8GB 4*2GB DDR2-1066 Dominator 8500C5D 5-5-5-15
[Mobo] ASUS M3A78-PRO
[GFX] nVidia GTX285 1GB DDR3
[PSU] Corsair TX850W APFC
Component overclocking abilities (stable Prime@30min):
[stock cooking and C&Q disabled]
FSB [200 - 270]MHz
CPU [3000 - 3350][email protected]
RAM [400 - 447][email protected]
NB/HT [1800 - 2200][email protected]
About point (1):
About point (2):
Any ideas?
FSB [200 - 270]MHz
