- Dec 4, 2005
Just wanted to ask for some opinions on whether or not my board is borked or what. Right now i'm running a vcore set at 1.4625v with LLC 0% and cpu vdda 2.8v. However my vcore has been fluctuating like crazy since i first bought it.
heres a screen:
as u can see my voltage is dropping as low as 1.41v and as high as 1.63v. The data was taken over a 7 hour period.
now i know some will point to my LLC (load line calibration) being on. I have also read that voltages will spike and in general should be turned off for high voltage overclocks. However, i have the same issues with it off. The voltages will still fluctuate over a ~.2v range.
Secondly turning off LLC results in the idle voltages to be much higher than needed for a stable overclock because it needs to be high enough such that it doesn't become unstable under LOAD. For example an oc of 4ghz w/ LLC off requires a voltage of 1.65v. Idle voltages are ~1.6v while under load the voltage drops all the way down to 1.4Xv!
These voltage issues have basically made my life hell when overclocking above 4ghz. Is this normal. Or is there rly something wrong w/ my board.
heres a screen:
