- Jun 5, 2005
- Vancouver, Canada
Are magnetic tipped screw drivers bad?
I have a screw driver here that is SLIGHTLY magnetic, so very slightly. It holds onto those metal scrapings but will not hold a screw itself. I used the screwdriver to screw in my motherboard and put on the heatsink and my computer is fine.
On the other hand, i have a powerdrill that is magnetic and can hold a screw. I used it to put the new fans into my case because its hard to make the threads. I also used it to put in the drive rails and the hard drive on. Everything seems to be working flawlessly.
If everythings so good. Then why do some poeple say NEVER to use a magnetic screwdriver/powerdrill?
Poll (sorta): Do you use a magnetic screwdriver/powerdrill?
