- Jun 5, 2005
- Vancouver, Canada
- Thread Starter
- #21
same here. never stripped any screw or rounding them.. so...
threeme2189 said:actually i don't think the magnet in on the tip. thats reinforced steel. the magnet is actually inside the handle and its magnetic power runs through the metal shaft and into the tip. its like making a magnetic chain of paperclips.
just my 2 cnts keep t3h change
JDXNC said:I can't stand the ratcheting ones, they are a royal pain in the arse... manual is the way to go. You need to build up some strength if you think putting in fan screws is tough I used to work as an industrial mechanic and put in hundreds of screws and bolts every day.... mostly by hand, not with power tools.... fan screws are a breeze.
SolidxSnake said:Amen.
Live up to the true man's way!
MANUAL!
techun said:magnets wont hurt your computer
atleast not any ive ever held
Susquehannock said:Using a power drill for PC screws is just asking for stripped threads IMhO.
