- Mar 9, 2008
Hello,
This is my first post, and I am hoping that someone out there can help me with this frustrating problem. My system:
Foxconn C51XEM2AA mobo
AMD Athlon X2 4200+
4gbs Corsair 6400C4 (4-4-4-12) DDR2 800
WD 74gb Raptor
7900 GS Vid Card
I had the system overclocked to 2.5ghz for a while when I had 2gb RAM in there, I added another 2 gigs of the exact same stuff, and started having posting errors occasionally, and the system would clock itself down. So today I tried to adjust the clocks and accidentally set something wrong - the cpu voltage to be specific. It froze during post VERY badly, with lots of '%' signs everywhere, etc. After powering it off for 10 minutes I started it up again and was able to get in bios - and set everything back to mobo defaults.
BIOS said it was running at 2.2ghz, and CPU-Z (most current version .. 1.44) said it was 1.8ghz. So I overclocked it - using a guide I found online http://www.legitreviews.com/article/373/1/, and being very careful/conservative, and got the system up to 2.8 ghz, easily. BIOS says 2.8ghz, CPU Z and Windows System tab both say 2ghz (each core). I clocked the CPU down to 1.7ghz, and CPU-Z read it as 1.2ghz.
I noticed that in BIOS I set the CPU Core voltage to 1.45V, and it shows up as 1.33 volts in CPU-Z. If I set it to be 1.3 it goes down to 1.18 in CPU-Z, its always about 91% of whatever I set it to be. In BIOS system monitor it reads the voltages and core frequency as what I want it to be, then in CPU-Z everything is much slower - presumably from the voltage problems.
I do not have nTune installed. AMD Cool'n'Quiet is disabled.
Please anyone? Any ideas? Did I fry my CPU and it is only running at a % of the volts I set it to? Or did I fry the motherboard, as that is the component that actually controls the volts sent through the CPU?
Thank you!
mC
AMD Athlon X2 4200+
WD 74gb Raptor
7900 GS Vid Card
Thank you!
mC
