Hello everyone,
So i got bored and started messing with the AMD Vision Control and tried the Auto Tune feature on the CPU Overdrive, I figure since it is using the multiplier and not voltage i will let it run threw the Auto-tune test. Well It tested to freq-4800 MHz and then became unstable and the system shut down. I then restarted the system and the Auto tune said test complete Manual overdrive now available up to freq 4700. At 4800Mhz by temp was 60 degrees C. and 1.4 V. After the Restart I opened CoreTemp 1.0 and now my Freq and voltage keeps fluctuating from .925V 1409 MHz at each Core and 6 Degrees C to 1.4V 4200 MHz which was the default setting. My Question is hwo do i get my Voltage Stable again or did i mess up my CPU.
my setup includes
gigabyte ga-970-ud3
fx-4170
8gb g. skill 1600
asetek 510lc watercooler with push and pull
power color 7870
corsair cmpsu-850tx
1tb sata III HD
64gb SSD
my setup includes
gigabyte ga-970-ud3
fx-4170
8gb g. skill 1600
power color 7870
corsair cmpsu-850tx
1tb sata III HD
64gb SSD
