- Nov 16, 2009
I've got an e6850 stable and smooth as butter at 3.7
I've always used Core Temp which gives me idles in the low 50's and Orthos runs into the high 60's. This is always as safe as I've felt pushing it.
Today I started reading about the differences between Real Temp and Core Temp and I read you should set your TJ Max manually? According to this my E6850 ought to be set at 80? So I download Real Temp, set my TJ Max to 80 and I'm idling in the mid 30's Orthosing in the mid to high 40s??? Is this for real?
E6850 @ 3.7, corsair h50 with two yate loons in push/pull intake setup
Also, how do I set TJ Max manually in Core Temp?
