- Jul 18, 2012
Yea I figured as much. I just want to see how much your processor influences this bench and if the 8350's are giving comparable scores to intel chips running the same GPU's.
Fortune, if you look on page 1 my 5850 was run on my Fx 8350 I was able to get a 2600.54 score that was the best I achieved on the AMD platform. This score was achieved on my Intel platform. I was also going to run my GTX 580 on both to see what the difference would be but on the Fx 8350/ GTX 580 platform my 650w psu isn't enough with both overclocked. So until I purchase a more powerful PSU I cannot run that test.Should add another column onto your chart adding "processor" and just put Intel or AMD..Curious if we will see any trends..I bet most of these benchmarks are being done on Intel platforms?
What cpu and gpu?
My current processor, but I have a little secret showing up in the mail tomorrow
I can only assume you're talking Titan, but I seriously doubt an AMD cpu will take you anywhere near 6k (unless you forked out $2k for Titan SLI).
Single|atminside|560Ti|Stock|2709.259
Got a bit more from it today
Screaming doesn't even describe this card right now.
That is exactly where my 560ti's capped in SLI: 1000/2200
Personally I didnt see any improvements from overclocking the gpu memory. But more than one member suggested I should OC my CPU more, but 4.5Ghz to 4.7Ghz didn't improve my score at all. I have 1333Mhz RAM as well, so I think that's a bottleneck. You could try OCing that, I hadnt had time yet. Or you lower your RAM clocks and see if that lowers your score.but haven't tried pushing the Memory (both GPU or DDR3), so I might have more to squeeze .
Oh boyWhen you went from 4.5 to 4.7 did you make sure it was pretty stable? Rember lost cycles kill your score even if you don't crash the test. Check WHEA errors too
Thank you!Welcome, you still have plenty of time. Great score!!
