Marathon: January PiFast
Nice score.
Looks like Ln2 may be needed to beat you guys. Some good scores!
I'm always lurking... Linky :sn:
But I think I'll be competing in the AMD section this month. I'm not going to push my 3770k on DIce again until I know it's true LN2 potential. And besides. If I bench AMD, then you guys can watch. :D
Nice run EarthDog, I have no more left in my 3570k so you got me beat, and 5.9ghz on dice is impressive :thup:
I think I'm getting my gears back into this so called overclocking
Intel/Luis_GT/3770K/Water/13.31
I have almost no control over how much voltage I use, and even I wouldn't go over 1.5 on air no matter what the ambient temp. Air coolers are relatively inefficient, and the ambient doesn't have a very large effect on the actual temperature of the die, which is what counts.
That's a complicated subject. With a standard (solid, no-heatpipe) heatsink deltaT die to air should remain fairly static as ambient temp changes.
However, heatpipe efficiency is best in a certain window. Using water as the working fluid (which computer heatpipes do) means that the best efficiency is had starting at around 40c up through right around 100c. Mind you that's heatpipe temps, which are rarely much over the ambient.
Below 40c the efficiency drops off, until at 0c (again, heatpipe temp) it drops to zero when the water inside the heatpipes freezes.
Just above 0c the heatpipe functions, but rather poorly.
For really cold ambient benching a solid copper heatsink with a ton of airflow will stomp a heatpipe heatsink into the ground.
If you use ammonia in heatpipes the efficiency window starts at something more like -30c or -40c if I recall correctly. Unfortunately due to the substantially higher cost (for ammonia, also for safe handling of ammonia and licenses and such) you won't find any heatsinks that use it.
Ambient still matters heavily with heatpipes, but the difference between a 15c ambient and a 5c ambient isn't nearly as large as 25c to 15c.
But isn't the water inside the heatpipes in a different pressure enviroment much like refrigerant inside a fridge's compressor and thus the boiling point is lower? Does it freeze even like that?
untouched.
Suicided samurai...
Yeah the water is all the is in the heatpipe. Some in vapor form, some in liquid. No air, nothing else. The boiling point is much higher than 100c as the pressure goes up with the temp (at 100c you'll have one atmosphere of pressure in there), but the freezing point is unchanged as it takes pressure to lower the freezing point and what the heatpipe has in it is vacuum.
