Johan, I'm going to assume AMD other then Ryzen is good to 5.0?
8350s at 8ghz+ run ~9m30s, so it would depend on which Ryzen you pick, (both Der8aur and Stilt did it as far as i know) and we don't know if they used the "conditioner" thinguie ?FX speed is unlimited, you'll never catch Ryzen even at 8.0 GHz
I imagine with cores turned off you may be able to give 4.4 or 4.5 a go!mackerel/i7-5775C/air/7m11.902s
What will possibly be my only DDR3 sub, unless I revisit the ram on this. Have to admit I chanced the OC somewhat. Temps seemed ok to 1.4v even with air cooling. 4.2 GHz was the last speed able to complete Cinebench R15, with HT on. So turned that off, turned it up to 4.3 and crossed my fingers. Didn't crash, I'll take it.
took your advice. here's the new run at it:
steveokinevo / FX-8370 / AIO / 17M 18.918S
C'mon bro, punch those clocks higher, let's have a FX showdown... I can hit 4.9ghz ~1.525v before my NH-D15 melts, so this isn't even my best score and you're on water. Hell I'll make the time to switch to my 4300 5ghz just to see the difference [emoji23]
need help tuning it better. i was sort of told the board i have may not take much more. if you have any recommendation that would be helpful. heres my build thread: http://www.overclockers.com/forums/showthread.php/783757-OC-ing-with-the-FX-8370
Shut it down to 2 coresneed help tuning it better. i was sort of told the board i have may not take much more. if you have any recommendation that would be helpful. heres my build thread: http://www.overclockers.com/forums/showthread.php/783757-OC-ing-with-the-FX-8370
