I fully appreciate that, I wouldn't not buy a decent board over one bad review. but the sheer amount of complaints with the board is what puts me off.
Also I need good software fan control which the Asus doesn't seem to be to hot at from what I read.
"Bundled Fan Xpert+ is limited to 60% as well, so equally useless. Tried Fan Xpert2 which isn't officially supported for this board but works anyway. Slightly better but doesn't allow fans to spin below their minimum startup rpm (even though all fans can go much lower than that once they spin). Buggy as well, requiring manual reload of fanprofile after every reboot. Litters the system with services and leaves tons of junk in the registry after uninstall.
Cpu fanheader can only control 4-pin pwm fans, a real shame if you already have good quality 3-pin fans like Noctua's."
3 pin Noctuas are exactly what I have...
Thanks for the suggestion though, I do seem to be struggling finding another with the same features.
