- Jul 28, 2014
- S. Flori-duh
My Dilemma:
I have a 9900k, 16GB 3200MHz G.Skill RAM, 970 EVO M.2 X4 SSD, and an Asrock X390 Taichi Ultimate (my 1st Asrock board ever) on the way.
I have 2 machines that I use mainly for gaming duties and watching movies/videos - one is my 4K TV/server/couch gamer rig that is on 24/7 in an HT case and theater room, air cooled and my other is my main gamer rig desktop with a full custom loop, 165 Hz G-Sync 1440P monitor in my office. I probably use the "main" rig slightly more for gaming, but I do like playing on the 4K TV with a controller in hand (Shadow of the Tomb Raider, AC: Odyssey, etc.)
The "couch gamer/server" is a 4790K at 4.5GHz (Noctua L12 cooler), 16GB RAM, and a single 1080Ti. This rig is super stable btw and mated to an LG OLED 4K TV.
The "main" rig is an X99 build consisting of a 5930K, 32GB 2400 MHz RAM, 2-1080TI's in SLI, 950 Pro M.2SSD - all on a custom loop water setup (EK blocks, etc.)
Which one should I upgrade? If I swap out the main gamer, it will be SLI 1080 TI's still (but no more 16X PCI E lanes on each card - probably irrelevant. If I swap out the 4790K and playing on 4K, does it even matter? I'm thinking it won't looking at benchmarks.
Again, 1st world problem, but a problem nonetheless. What would you do? Initially I was thinking to replace the couch gamer, but now I'm thinking the main gamer makes more sense since it's on a 1440p 165 Hz monitor which can handle the increase in frame rate; and I can overclock the hell out of it being on a custom loop, whereas the couch gamer won't allow for any overclocking being it's in an air restricted case in a cubby-hole TV furniture/stand. The case is maxed out with all Noctuas F12 fans (and the 80mm equivalents) for max airflow (Silverstone GD08)
Cheers,
Cheers,
