- Aug 15, 2010
- California
First post so I'll do a quick background. I'm a 'teach yourself' type of guy and I started on computers early in high school. Unfortunately, after a rather successful venture in building my first PC, I hit personal problems and had to give it up, but the joy of tinkering with it still lived on (yes, I am still running a 478 P4 as we type). Fast forward through almost a decade and a half of intense civil litigation, paying for school, at one point working three jobs, and getting married and I'm finally in a place to pick up some of my old hobbies.
That said, please forgive the rather noobishness of my questions or understanding that may come out in some instances - I am still going through a crash course in the last decade of computers. Also, 95% of my ideas are born of my own head and probably some of the stupidest ideas you will hear. I haven't been reading topics and thinking "well what about this..." When I built my first computer, water cooling was considered cutting edge and only done by those CRAZY people who wanted bragging rights. I thought my ideas were going to be bleeding edge and pushing the envelope, but I came to find out I'm actually in the realm of retro with my ideas - which is a good thing though because it means there is experience I can draw off of.
Also, I'm NOT looking to be held by the hand and guided to my destination, but looking for more of a "That's the wrong direction; go this way" type of approach. I'm also not 100% against pre-fab, but as a machinist and a tinkerer I'd rather spend twice as much for a less effective and hideously ugly unit and KNOW exactly what's going on inside than have a store bought unit. I also have NOT set my mind on hardware so these are more general questions.
That said, I have several questions. Most are the results of reading and research that has addressed one side of an issue but not fully addressed the entire issue and I'm either curious or confused. I have tried using the search function but sometimes that was a dead end, the term(s) were so common I couldn't find an answer, or worse - it caused even more questions. So here we go:
1. If I go water, I'm thinking of making my own blocks of solid copper with threaded barbs brazed in. My initial thought was to mill a channel with a ball endmill in a spiraling type pattern with an inlet at the center and the outlet towards the edge, a thin 1/32 or thinner plate would be brazed of soldered to closer it air tight with a quick pass by a fly cutter and hand polished to ensure a flat surface. My logic was this would not cause a reduction in the line and pressure/flow would stay the same, the coolest coolant would be delivered to the hotest spot first, it would maximize time over the chip without allowing stagnant areas (such as corners if it were square in design), and would be thin walled to allow maximum heat transfer and minimal heat retention by the block itself.
However, I have seen a lot of designs that look like flowers, or mazes with dead ends, etc that seem contrary to my own logic. I also read a thread, I think though the actual extreme cooling FAQ, that stated something along the lines of you want flow rate in the lines to be high but in the blocks to be low. Just curious is there a fundamental flaw in my logic or my block design?
2. In a radiator type water cooled setup, would a heatsink on TOP of a water block be of an benifit, or would it act as a heater and push ambient heat into the block as opposed to pulling heat and putting it in the air (assuming proper air circulation in the case)?
3. I have read the thread on why mini-fridges won't work and it makes sense to me. However, that seems to address the issue of using the fridge itself as a cooling tank. What about stealing the compressor system and NOT using the box, replacing the expanssion side of it with copper tubing and splicing in a block of similar design as described above. If my understanding is correct, this would essentially be a VERY crappy phase change system. Could something like this work if you used a full sized freezer or AC unit or would it still be too much load for an effective cooling system on a PC?
4. I had thought of going hybrid and came up with an idea as a cross between the two above, which I later found out is actually a water chiller. Would using a method as described in question 3 but without a block and with the copper tubing wrapped as a coil and placed in a rather large reservoir (5-10 gallons) of a regular water chilled system be an effective way to bring down the temps below ambient? I'm thinking of leaving the unit always on, and then running the actual water system only when the computer is running (up to 12 hours a day). The large insulated reservoir would take a while to hit it's balanced temperature when the computer was off, but once there the compressor unit would only kick on and off every now and then to keep it at that temperature thus reducing the load on it considerably. Also the large reservoir would require large amounts of heat to increase it's temperature drastically so the compressor would not be under too much load to keep it within reasonable termpatures. Of course for the same reason if it did get heated up, the compressor would be put under that much more load as it had a large reservoir to cool as opposed to a small system.
5. Would the system described in question 4 benefit from a radiator at the end of it's cycle before being dumped into the large reservoir, or would that simply heat the line with ambient heat? Would it be a good idea to have such a radiator with a fan on a temperature setting so it only kicks on after extended periods of use or would it not really be necessary?
6. If I were running a LOT of blocks (CPU, RAM, mosfets, northbridge, multiple GPUs and their ram, etc) which system do you think would be more effective for 24/365 opperation: The system described in question 4 or a straight distilled water system on a smaller reservoir (say 1-2 gallons) using multiple radiators that are stationed with each one between sets of several blocks? In case that was confusing, something like this:
Pump - > Radiator 1 -> CPU -> mosfets -> Radiator 2 -> RAM -> Northbridge -> Radiator 3 -> GPU 1 -> GPU 2 -> Radiator 4 -> Reservoir
7. Would a water system as described in question 6 be hurting itself by drawing too much heat from items that could be otherwise air cooled with fans and heatsinks? Would it be better to focus on the major components, like the CPU, RAM, and GPU(s) and leave the others to more passive methods?
8. Lastly, what is the general concensus on using TIG welding coolant in place of water? If I use only copper in my system corrosion shouldn't be an issue, and the TIG coolant is specifically non-conductive (it has to be), has better heat retention than water, and has an anti-clogging oil agent to keep small pumps clean and lubricated. Any thoughts on the subject?
Thank you in advance for any help you guys can give and sorry for bombarding the topic with questions. Also, I apologize if any of these issues are addressed elsewhere.
-derracs
-derracs
