Just remember that for any AMD mobo if you go off the 1333mem divider you will likely need to bump the IMC (cpu-nb) voltage a notch to make things stable. I had to do this with my 89FXA-UD5 to get my 1600mhz RAM to run on the 1600mhz divider. So if you get some crazy problems bump that IMC up a notch maybe 2 depending on how big a bump you can get. My board default IMC is 1.1v and one bump puts me to 1.125 and two bumps puts me to 1.15v. Those are kinda small bumps and it really will depend on the mobo, ram and what slot you put them in. I have mine in the white slots furthest away from the cpu due to my cooler. You might have to go more bumps in voltage with the blue slots as Gigabyte states that for running over the 1333 speeds and to reach the max oc of RAM for the board to use the white slots.
