- Jan 10, 2008
Hi. I've got two questions about the MCP655.
The first is how the fittings work on it. The body is made of plastic, so I'm wondering how you fit your tubes onto it. Is there any way to put compression fittings on it? Or do you just have to sleeve your tubing around and use normal fittings?
The second is that on their site there's a diagram showing that the horizontal barb is the IN port and the vertical one is the OUT port.
Am I somehow misinterpreting this? Does it seriously send the water out vertically and take it in horizontally? If so this screws up my ideas of how to put it in my case so that the vertical is just straight below the reservoir T_T
Thanks in advance
Thanks in advance
