- Oct 20, 2016
- Thread Starter
- #21
If it will run ok on a single stick like the last ram, I'd RMA the motherboard.
I was leaning toward the board on your last set.
Well I decided to go to the Asus website to look up their info specifically. The memory I bought, both sets actually, are not on the QVL sheet at all for my motherboard. Other kinds are. I'm guessing the QVL sheet is the list of memory that has been matched and tested successfully, right?
I mean I would think that if it's not on the sheet then it's not supported? I'm going to return this memory and buy a set specifically on the sheet. If it works then I'll know it was my fault. If I have problems again I will RMA the board.
