1866 is not the normal or default speed for that memory. It is the XMP profile (EXtreme Memory Profile). Typically, RAM is marketed using the XMP speed rating but motherboards typically default to 1333 mhz. which is kind of the generic DDR3 transfer rate.
You may need to go into bios and manually configure the voltage and the timings.
That motherboard should have a "XMP" setting for the RAM in the bios and it may or may not configure the voltage and timings correctly with that but try it and then if it still doesn't work, configure the voltage and timing manually. You would probably need to take some memory settings off of Auto in order to do that.
