Hello all,
I'm hoping for a bit of ram advice. I'm using a Gigabyte X470 Gaming 7 with 2700X (not overclocked) and Crucial Ballistix Elite 3200. The ram defaulted to 2100mhz, so I enabled XMP in the bios which resulted in boot failure; after a dozen or more restarts I got into the bios and turned off XMP. Since then I've been gradually upping the speed until I got to 2933mhz 16 18 18 38 trc 52 at 1.2v, which was absolutely rock solid. Today I tweaked the speed to 3000mhz and major boot failure, again taking numerous reboots to eventually get into the bios and wind the speed back a notch. I know the voltage should be 1.35v at 3200mhz, but should I go straight from 1.2 to 1.35 at 3000mhz, or try something in between, say 1.25? Also I can find no recommended trc setting for this ram at particular speeds, but 52 at 3000mhz seems quite low from other specs I've seen, so is it worth changing it?
Thanks in advance.
Thanks in advance.
