Hey,
I'm planning on building a mITX build!
Specs:
Asus DirectCUii OC r9 290
i7 4770k
(still have to decide which cooler, air or water (aio)
8gb crucial ballistix single stick (first upgrade will be 16 gb total)
cooler master G750M
Cooler master Haf Stacker 915F
but... what m itx mobo should i choose? I read on a couple of forums that m itx mobo's support less vram (video ram) than normal atx or itx. I really need help picking one as cheap as possible, really really cheap though.( keep in mind the gpu i'm using has 4GB of vram)
I won't be overclocking with this build but i will swap out the cpu for an i5 4690k on the MITX build and put the i7 4770k in my next computer when the money's there...
summed up:
I need an as cheap as possible mobo, no overclocking or alot of connectors etc(sata, internal usb 3.0, etc.)
I really need help!!!
Thanks in advance!
Specs:
i7 4770k
cooler master G750M
summed up:
Thanks in advance!
