Hello everyone, I recently just bought the parts for my AMD 3D Rendering and Gaming build. I was initially just going to put 8GB (2x4GB) of RAM in the PC, but I now see that my Mobo came with a free kit of 8GB (2x4GB) RAM. The problem is that the 2 RAM kits are different Manufactures.
Here is the Two Kits:
Initial Kit - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Free Kit - http://www.newegg.com/Product/Product.aspx?Item=N82E16820313080
Both kits have the same Timings, but one is rated at 1.5 Volts and the other is rated at 1.65 Volts.
I would like to know if it would be safe to put these two kits together? And if it is safe, would having both in mess with my overall performance of just having One Kit in?
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
