I just got my mach 1 and to my dismay it won't help me overclock any higher. Its like I hit a wall. I was running 210x12.5 or so on air with a 80mm tornado and ax-7 sink. I was using 2 volts that read out to be 1.9 on MBM. My computer is listed below. ( in sig)
I can't get anymore overclock by increasing the fsb or the multiplier. Even when I drop the FSB and increase the mult, still nothing. I get the blue screen that says something about my hardware failure or something to that nature and then it restarts if I go higher.
My temps at stock mobile 2600+ settings are -1 idle 6 load or so.
Running at 2 volts its 27 idle (haven't really seen a load temp)
I'm thinking it should be a lower temp but don't really know.
I am using arctic alumina also.
I have active mosfet cooling with sinks, a northpole on the NB, and active SB cooling. Also I have various sinks on the pll's and ram chips.
Is there some sort of wall that I have hit.
