I have an external USB audio interface/soundcard http://www.rolandus.com/products/duo-capture/specifications/
so I don't think audio matters.
I'm not doing RAID or anything like that, I just have one SSD drive and that's it. Not sure if that matters or with the M.2
I threw the %10 chance of OC'ing out the window and won't do it. So after what I noted, is it worth canceling my order for the Extreme 3? If I were going to OC, I'd get the extreme 6 anyway.
The guy on the other forum when I pointed out I sort of took his advice over the extreme 3 recommendation, he didn't have much to back it up, "I do not trust the reliability of Asrock boards. They spec out nice, but do they last? History indicates that they do not.
I'll take that Gigabyte over anything Asrock makes, simply due to both company's comparative reliability records.
The other forum probably is populated by enthusiasts. This one is populated by conservative builders who place reliability above performance. That's why I said to stay away from used Ebay boards, regardless of what it is"
I realize the extreme 3 probably has a better resale value in 2-3 years if I upgrade but I'm not worried about that, not worth the hassle of canceling order. Plus I bought it from here which is like $1 more than newegg AFTER newegg's rebate, rebate can be a PITA and not worth it to me unless it's at least around $10 cheaper overall.
http://www.directron.com/gaz97hd3.html
I guess bottom line is im just asking if there's any performance difference if I'm not Ocing. Two posts above say no as do a couple others but oen post above seems to suggest that the extreme 3 would be better performance even if not OCing.
thank you. I'll go with the 1.5V. Googled something like "1.65 ram 1.5V" and found a lot of threads, the consensus is it can potentially damage CPU, voids warranty, but you can change settings in BIOS but I don't want to mess with BIOS.
It won't damage the cpu. That's garbage. Trust me.
Just go 1.5v anyway.
i read people on Tom's etc saying stuff like 1.65 means it's crappy ram that they ramped up to 1.65 Volts to make it faster
But why are you buying 1.65v memory anyways? That's usually indicative of cruddy manufacturing, at least if it's rated at speeds one commonly finds 1.5v memory for.
In this case I would get different ram There is NO need for 1600 MHz ram to EVER be over 1.5v the only reason that is 1.65v ram is that is it crap ram they are raising the volts on to get it stable. Find a 1.5v set and enjoy. Won't harm your system you're just getting inferior ram for the same price.
I completely agree with the above poster. Never buy ddr3 memory that needs over 1.5 volts to run its rated speed. Its poor quality memory
Though, Haswell has recommended voltage of 1.5v but you'll still be able to use this RAM on mobo and cpu without any problem. No issue there and as you are not overclocking so you are safe there.
You can order 1.5v RAM still you are ok with 1.65 v RAM. Choose whichever is comfortable for you. There is no issue in either selection
I still think I'd rather spend ~$25 more for 16GB (~$150 total) if it's 1.5 but better than that 1.65. I like the 1.5V low profile one also, not that I'm going to OC, but it would be easier to resell low profile RAM.
