- Apr 18, 2011
I have an older am2 mobo (ecs k8m890m-m) that i just replaced with a new setup in my little server. I went to throw this mobo into a new case it wont power on at all. I push the switch and nothing happens at all. I've tried using a different switch, used several different powersupplies, changed out all the hardware (ram.cpu.etc), i tried touching to pins with a wire to jump it, taking it out of the case to see if its grounded or something. I am running out of things to try and im wondering if maybe this mobo has finally bit the dust. Any opinions? It worked before I moced it, 15 minutes later after its in the new case it wont power on.
thanks in advance
thanks in advance
