- Mar 21, 2002
- pittsburgh pa
delta 80cfm'r need i say more? well wow that burns!!
countless screwdriver,dremel,x-acto,scissors,sheet metal,metal splinters,cut up pop cans(cheapo ducts),boiling hot plastic adn sticky hot plastic from dremel cutting, electrical shock(dont let ur friend take his ccd out of the tube and then turn it on when ur touching it/ u see this little wire runs up the side and well les jsut say ZZZAAAPPP. try it u might like it.),fire(yes on an old at case i had some bare wires touch and the insulation actually kinda uh caught on fire),ect
well u get the idea and there are plenty more i would like to say however superglue is a great clotting material for a cut but so is table salt try it. works great! i do it jsut about daily its like oh sh|t i cut my hand *runs to kitchen finds salt* [dump] wow that burns!!!! awww all better now...
