Monitor Recommendation?
Pepi93
Just got a Strix 2080ti so I'm thinking to upgrade my monitor.
I'm using a BENQ BL3200 right now, which is a 10 bit panel. No HDR though.
I want a 32 inch screen (no ultrawide), capable of 144hz, 1ms preferably, 1440p resolution, G-Sync/Freesync capable. I don't mind 4k but I won't really use it. I'd rather shoot towards the higher hz at 1440p. I sit approx 3.5 feet from my screen.
I play open world, 3rd person perspective, league of legends, sim racing (forza) but no first person shooters unless I'm forced as is the case with Cyberpunk 2077
I've been looking at monitors but for what I want above, it just seems that there aren't that many options with the above mentioned specs.
Thanks.
Check out hardware unboxed, they cover a ton of different options.
is a popular 32'' display, for example, and I think checks most of your boxes.
I feel that 32 inch is an overkill for gaming monitor.
Check this video out maybe you will get new thoughts
[video=youtube;EWI4N3khLKo]
I don't mind the size, but the resolution for the size and distance. At 32" and 3.5', I'd be looking at 4K. You should find some (expensive) of what you're looking for at the higher res.
That said, a 2080 Ti is barely a 60/Ultra card so keep that in mind.
