Hi guys My new system is all up and running (though I wish the processor ran a little cooler, I need to make some serious case adjustments, when I run it open, I drop from 31 deg idle to 21 deg) yay!
However, I started with the BIOS CPU Temp warning set to trigger at 60 degrees. I start up Prime95, as soon as it hits 50 degrees according to CoreTemp, the temp warning starts blasting. I bump it up in the BIOS to 65, the temp warning starts blasting when CoreTemp reaches 50.
OK, so, either CoreTemp is reporting bad numbers, or my BIOS is reacting to bad numbers.
Can I trust that the BIOS option to automatically decrease processor speed and such when it hits thermal emergency kick in properly? I don't know what to trust, what not to trust, etc.
