Hello All,
First, my motherboard is a GIGABYTE GA-Z97X-UD5H-BK (Z97).
I have a Silverstone PWM fan controller hub. For those not familiar with it, it allows you to connect up to 8 PWM fans into the hub.
The hub is designed to only send/receive a signal to and from the mobo through one of the plugged in fans (the hub denotes which fan is used for this).
The hub it self is powered via sata power. The hub then connects to your motherboard via a 4 pin connector.
Now, because the hub is powered by sata, the 4 pin connector which connects to your motherboard only actually uses 2 pins (the signal pins).
The power and ground pins are empty.
The issue I'm seeing is I'm unable to control the fan hub, all fans run at 100% no matter what I set the BIOS too.
When I plug one of the 4 pin fans directly into the motherboard (not using the hub) I'm able to control the fan with no issues.
At first I thought it was an issue with the fan hub until I realized I'm also unable to control my PWM D5 pump.
The PWM D5 pump gets its power through a molex connector and to control the pump there is a 4 pin connector which plugs into your mobo.
Again, this connector only actually uses the signal pins, the power and ground pins are empty.
I've tried every PWM header on the board with the same result.
It appears the mobo only recognizes a PWM controlled device if it is not only sending and receiving a signal from the device but also supplying it power.
This would make sense as any 4 pin fan I plug directly into the mobo can be controlled with no issue.
Has anyone else experienced this before? Is there a walk around for it?
I feel my only solution at this point is buying an Aquaero 5LT to have any control.
Thanks
Thanks
