varunshetty2893
- Aug 4, 2012
I'm looking to set up a budget gaming rig that can accommodate the coming generation(1.5 - 2 years) of games(even if at low settings).
After a lot of comparing, I picked Phenom 1090T over the FX series and eventually, after reading a lot of the threads on this forum, settled for a Phenom II 970 BE since a lot of people said it's only marginally lesser than the 1090T in terms of performance.
What I'm looking for is to be able to use Crossfire to accomodate the games that come out in a year or so, under the assumption that the HD6570 1GB DDR3 I'm buying might not be enough at that point in time. In which case I could use the added functionality of the integrated card. I have picked this Gigabyte board as of now - http://bit.ly/OHhauZ
Will it be sufficient for what I want of my PC? And under what power supply/cooling conditions could I overclock this rig?
Also looking at 8 gigs of RAM (Corsair) and a 1 TB HDD, if that helps. Thank you.
